How high is high for milage?
Old 02-26-2008, 08:00 AM
Dele's Avatar
Default How high is high for milage?
Im looking at an LS1 engine and ive found one with a T56 thats done 113k, i wasnt looking to do more to it than bolt ons and a mild cam, can i expect many problems from this?
I know it depends on how the engines been treated but i didnt know if they are prone to breaking after a certain range.
Thanks
Old 02-26-2008, 08:07 AM
andrew69_04's Avatar
my motor im using for my swap has exactally 113k on the clock. I would assume you will be fine. it all depends on how had those 113k miles were and how often the motor/tranny was serviced.
Old 02-26-2008, 10:04 AM
Dele's Avatar
In that case ill buy it
Old 02-26-2008, 11:18 AM
Boosted1320's Avatar
miles mean nothing to an engine....engines dont travel distances like rear ends and stuff. 100 miles could be 100 miles driven or 400 1/4 mile passes....unless you physically drove the car through all the miles you will never know. With cheap oil and no maintenance it could be a POS. Or using good oil and taken care of it could look like new inside???????
Old 02-26-2008, 11:24 AM
THE CHOP SHOP's Avatar
If you scroll down a read a few other posts there is a guy with 211k wondering about a short block but says it is still running great. I think the post is just a step to planning for the what if when you know you have higher miles. I have a friend with a motor that has 119k on it and it runs great!
