Who's broken a Truetrac?
Old 02-26-2008, 08:35 PM
Mike2kZ's Avatar
Default Who's broken a Truetrac?
How many people have broken a Truetrac and at what power level? Include the full story if you want
Old 02-28-2008, 08:46 AM
chieftransam's Avatar
Good ?, I would like to know the same thing. Anyone?
Old 02-29-2008, 08:45 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I have broken one.
It was an ORIGINAL tru trac, not the UPDATED Eaton unit.
Rear End: Moser 12 bolt, April 2004 Build date.
Options: 3.42's, 33 Spline axles, upgraded diff cover
Car: Current car; 2002 T/A, M6, 3" steel DS, SLP LID, Headers, cat back, stock tune, Making 326 rwhp (corrected) M/T ET street radials. Stock clutch. No line lock
How I broke it: Burnout @ the track. At LVD (Lebenon Valley Dragway), I had no line lock, and LVD doesnt put much water down.
This was my 1st manual car that i race.
A combo of no line lock, tires that have PLENTY of stick and messing up the burn out the car wheel hopped BAD, it was nearly earth shattering. The car didnt feel right after that.
Over the next few days the rear diff acted exactly like a TRUE locker, the wheel was binding up bad on tight turns. It sounded very broken
I ended having to replace it with a new UPDATED unit, since the axles are cut for the tru trac, I couldnt go to a Eaton unless I wanted to do axles too.
I upgraded to 4.10's at the same time. Also armed with line lock, the car did solid burn outs and I went to the track again a bunch of times and never had a issue since.
The diff physically looks fine, nothing exploded, actually the rear stopped acting up right before the job but I didnt trust it.
Old 02-29-2008, 10:32 AM
382ssz28's Avatar
DTS says 12 bolts are usually good to 900HP-Dana 60 is good to about 1100HP. I have no problems with my Dana.
Old 02-29-2008, 10:38 AM
99blancoSS's Avatar
so did you break a tru trac? Because thats the question.
Old 02-29-2008, 11:09 AM
ICRAZY6's Avatar
Good info. How about anyone with a 9"? I'm getting ready to get on installed this spring.
Old 02-29-2008, 04:15 PM
00WS6WHITE's Avatar
I broke a true trac's with 400 rwhp and 456 rwtq and I was launching at only 5400 rpm on the 2-step with et streets. This was also in a Moser 9". Now I have a locker. Only been back to the track once with the locker and was launching at 5500 or so on the 2-step and she seemed to work fine.
Jimmy
Old 03-01-2008, 08:58 PM
BigJls1's Avatar
hmmm. only m6 cars. No body broke one with an auto ??
Old 03-05-2008, 05:13 AM
Big Bird WS6's Avatar
Jimmy
on a locker not. the spider gears are only rated to a 3500 rpm launch. buddy of mine got screwed by moser on that. true trac are only rated to a 4500 rpm luanch.
Old 03-05-2008, 02:29 PM
RAGENZ28's Avatar
I don't get the post, a locker is the strongest way to go next to a spool, I've seen guys run 8's on lockers.
Old 03-05-2008, 04:16 PM
Websy21's Avatar
Ya but I don't like how they lock and unlock whenever they feel like it. In a auto the truetrac will be allot more promising aside to high rpm clutch dumps, in a 9'' of course not a 12 bolt.
Old 03-05-2008, 04:18 PM
John35thSS's Avatar
I broke a trutrac in my 12 bolt, biggest waste of money and worst experience on car to date.
No wheel hop, the biggest joke is it replaced a US gear posi that was only rated for 450 flywheel hp THAT DID NOT BREAK.
Car is 656 rwhp LT1 blower car that I made 4 passes with the truetrac.
Not only did the case crack when I replaced the posi the 3 gears on each side had ground into the case spitting metal into my diff and messing up my bearing and gears.
John
Old 03-06-2008, 04:55 PM
00WS6WHITE's Avatar
I don't understand what he is saying either. I have made about 5 passes on the locker with no trouble. A buddy of mine with the same rwhp but has about 50 less tq is on a locker also. He sets his 2 step at 6000 rpm and hasn't broke his!(this is with a 9" also)
Old 03-07-2008, 08:04 AM
cam
cam's Avatar
I have a fresh one to install for this season. I'm not making huge power so i hope it will be fine. This is an 8.8 application so a little different. I searched and searched and posted all over the Ford message boards and I couldn't find one single Truetrac failure in the 8.8 rears. I launch at 5500+ so we'll see soon enough
Old 03-07-2008, 03:57 PM
ok. call moser. hell call the company that makes a detroit locker. the thing is only "rated" to 3500 rpm launch. it is just a rating. but my buddy broke his on a 6000 rpm launch. so he called moser. Moser asked what rpm he launched at. he said 6000. they said sorry that voids warrenty. only rated/warrented to 3500.
now do you understand?
Old 03-07-2008, 04:08 PM
cam
cam's Avatar
I fail to see how RPM of the launch can even be considered a factor. I could launch my 125CC 2 stroke bike engine powering a truetrac equipped 12 bolt at 12,000 RPM and it wouldn't even spin the thing let alone hurt it.
Theres too many factors that come into play to just rate a launch RPM so whoever told you that is crack smoking. Power levels, car weight, traction, clutch type, suspension set up etc etc etc. all play a gigantic role in how severe the shock is on the differential so its senseless to say they are rated to a certain RPM clutch dump.
The word on the boards is the Truetrac is rated to 600rwhp from what I've seen posted by various sponsors who sell the TrueTrac.
Old 03-07-2008, 08:15 PM
00WS6WHITE's Avatar
Think what you want man. But, my buddy has done the same thing over and over probably made 50+ pass's on the 2 step set at 6000 r.p.m.(sometimes he sets it alittle higher) He is also on the stock tq arm and stock lca's. They have been boxed in for reinforcement though.
I can't vouche for mine just yet. But for what pass's I have made and trying(I mean really trying) to break it on the street. Mine has held up perfect. I actually hate the damn thing it is to noisy. But, it works and works good.
Jimmy
Old 03-07-2008, 08:31 PM
cabel1's Avatar
A friend of mine had 2 years on his true trac in a 10.0 BB Chevelle on a 12 bolt with no issues to date.
Old 03-21-2008, 12:58 PM
Jimmy
think what i want? i aint thinking it. i know it. call moser. i aint just talking out my ***. this is really called on stuff. not just my opinion.
Old 03-24-2008, 05:01 PM
BigSteele's Avatar
It makes no sense though. It may have an estimated HP rating but a "RPM launch" rating is just dumb.
Quick Reply: Who's broken a Truetrac?
