Motor Swap
Motor Swap
Ok guys, I have a friend that has a 55 chevy with a 98 LS1 that has some slight engine noise and $1000 that he wants to swap me for my LS1 out of my 01 Camaro. I plan on pulling my motor for a rebuild to get ready for my APS TT kit anyway.
So, what are the reasons not to trade? I heard that the 98 block is not as good what is your thoughts on that. Can I just swap the intakes so that I can keep my ls6 intake his EGR has already been bloked off? I have new heads for my motor but I know that the valve covers are different. How bout the coil mounts?
Anything else I miss?
I knew about the oiling issue. Don't know if it would be a problem or not, obviously GM thought it might be cause they changed it.
I forgot about the thinner cylinder walls. I already have pistons that are 3.905 bore. So, correct me if i am wrong but that is pretty much a deal killer.
i say sell him your motor outright and build a new one on an ls2 block you can get 2500 or so for your motor less if you keep thing like the intake, heads, oil pan, ect. or you could sell him your good short block after you get a 402 or something
Just found out that the guys motor is a 99 not a 98. I believe that the 99 still has the oiling issue but does it have thicker sleeves? Is the oiling issue something I should worry about? Keep in mind I am doing a forged rebuild for an APS TT.
