Burn't Clutch MMMM
Burn't Clutch MMMM
Well I had another thread (Deleted it) stating I'v been having trouble getting into any gear cold and reverse alot (90% of the time) so far I did Orielly's DEX III and some generic DOT 3 (said synthetic made sure I flushed it totally clean did about 24 oz through it)
Anyways today I popped the clutch to get a little smoke show for a few friends (started at about 4k) let off and started revving up to bad it didn't let go.. got a nice clutch smoke show while moving still (5 mph) don't know what happened but as soon as I finished that I had to turn her off to get her in gear let it cool down checked fluid (dark grey go figure) and its easy to get into gear again (easier then ever..)
I don't know but this is pretty frustrating.. car has a reman T56 Tremec in it put in a around @ 50k miles car has 94k on it now (has a reman badge stamped to it so I know that parts true) he said they reused to stock clutch since it was fine and I imagine its the same hydro's (2000's)
Currently I got some Mobile 1 ATF Synthetic Tranny fluid (4 Quarts) was going to buy some synthetic clutch fluid and flush a whole bottle threw it to make sure the conventional(or cheap synthetic is out)
I'm pretty lost at what todo It feels like its something hydraulic... I goto school for auto mechanics it this has me stumped thank god the clutch still chirps 1st-2nd and dies in 5th still damn crazy stock clutch!
found some interesting stuff after 2 days of looking for Master/Slave Cylinders
Orielly's and Advance auto said they are discontinued dealer parts (Slave).. bullsh
Advance Master is $121.. Orielly's is $71.. Auto zone's $91.99 - auto zones slave is $91.99..
rockauto.com is $58 Master by wagner, Slave is $69 (loaded with TO).. by Raybestos
But nothing has lines does the line really have to be replaced??? ima just buy the master/slave from rock and do the drill mod.. hopefully it helps my situation alittle at least ill have good hydro
I wouldn't say so. I'm not convinced that cheaper brands from auto parts stores are OEM quality by any means. At least with the GM parts, you know you've got good quality components.
and GM quality.. think of the opti spark... even OEM ones don't start 50% of the time
I used heater hose, dot 4 synthetic and spark plug wire fire boots.
That will just protect your line from the heat of the exhaust, it will still get a lot of heat from the back of the engine/clutch. Change your fluid on a regular basis, especially if you track it.
