question on drill mod
Old 02-27-2008, 07:45 PM
SLP Firehawk's Avatar
Default question on drill mod
i read all about the drill mod my question is simple.. why do i need to remove the master and the line to drill the hose? can't i just disconnect it from the trans drill and flush the metal out of the line and then continue on with the flush of the whole system?
Old 02-28-2008, 06:15 AM
wrencher
wrencher's Avatar
It is quite a challenge to remove the roll pin from the master to relaese the line witht the master installed.
It also helps to have the assembly out of car to bench bleed it before re-installation.
Old 02-28-2008, 07:22 AM
ghettocruiser's Avatar
Are you thinking you drill the end that goes into the trans??? If so...like wrencher hinted one...its the end that goes into the master. Ill venture to say you wont get the roll pin out with it still installed. Not to mention fluid will go all over the place and it will eat your paint.
You gotta pull it all out.
J.
Old 02-28-2008, 08:51 AM
oh so you dont drill the end that does into trans? that would explain good thing i asked. will the set up leak fluid when i pull it out cause yes i know it eats paint.
Old 02-28-2008, 02:27 PM
RedLS's Avatar
No, when you disconnect it from the trans. the quick disconnect it will seal itself. To be safe get all the old fluid out of the reservoir, and cap it off, to start the project. Your gonna have to re-bleed the system anyways. Good luck
Old 02-29-2008, 08:10 AM
Yeah just pop the disconnect and wipe it off real good. It wont leak anymore fluid, unless the fitting is bad. Then get a bulb syringe (I stole the turkey baster...shhhh) and suck out the reservoir. I stick a couple paper towels in there and put the lid back on without the little black seal...just in case. You'll be ok then....the system is pretty fluid tight when its out like that.
J.
Old 02-29-2008, 04:24 PM
My Car Has 49k On It Do You Recommend A New Master? I Was Going To Try The Drill And Flush Before I Spend The 140 On The New Master
Old 03-09-2008, 05:31 PM
hndakilr's Avatar
i only paid 100 from sdpc for an 01-02 master
