Help! installing YT rockers
I've got AFR 205's milled to 59cc, LG G5X3 cam, 7.35" pushrods - this setup is supposed to work perfectly with the stock rockers. The only think that I'm doing differently is installing YT 1.7 rockers. Will these pushrods work? We've tried adjusting the rockers with and without the shims - with the shims, the rockers have a lot of "slap" to them still. Without the shim, I get 3 1/4 turns on the intake and 1 1/4 turn on the exhaust - doesn't seem to be right either... any help? we're knee deep in the middle of it right now - call my cell and help me out please! 817-819-4173 Thanks!
The first thing you need to do is get the wipe pattern correct. Measuring with an adjustable prior to doing the wipe pattern is a waste of time. Here is a link to my wipe pattern adjustment. Once you get the wipe, measure for the pushrod. The YT instructions are confusing at best, throw them away.
LINK
LINK
I have not installed yet, but I am using Morel lifters which are taller and require less preload. I plan to have Terry Manton make me a custom set when the time comes. I bought a single pushrod from him for use during assembly to check clearances and things and it is absolutely gorgeous.
