ARP Head Studs go by Block or Heads?
Quick question here... I searched and couldn't find much. When ordering ARP head studs, there are 2 listings, one 2003 and earlier, one 2004 and later. Common sense would tell me to go by the year of the head as the difference is most likely there, but I just want to make 100% sure before I order something.
Also, assuming I am correct, I have 2004 241 heads, but want to switch to 317 heads. If I order the 2004 and later studs do I have to look for a certain 317 head? I have an LQ4 block, 2002 I think.
Thanks,
Adam
Thanks,
Adam
Hmm, odd. So some of the bolt holes in the block are deeper on newer models? Seems odd since you don't gain any strength in a threaded hole after you have as much threads as the bolt is wide. Guess I'll double check the year on my motor. Technically you could use the 2003 and earlier studs on any block then, correct?
Thanks for the reply!
Ahh so it's the other way around. Newer is shorter. So pre 2004 block = pre 2004 studs. Easy enough, thanks!
On a sidenote, then you could technically use the newer studs on any year, correct? Do they offer any strength benefits? I can't imagine the new way is any weaker...
i wouldent swear to it because its been over a year since I did heads on an older block but I thought the 2 outside bolts were longer, im pretty sure its the holes that have the head dowels in them, either way the point is they are different and you need to get the right studs for your application. if your block is 03 or older you need the set with the different long and short 11mm studs
http://www.exoticperformanceplus.com....html?item=720
1997-03
http://www.exoticperformanceplus.com....html?item=721
2004-up blocks
Bob
1997-03
2004-up blocks
Bob
