Amount of HP to reach my goal??
To be competitive in the class I want to run, I will need to click off some mid to low 5s in the 1/8. I am building either a 408 turbo or LSX turbo setup. This is a track only car. I am trying to decide on a turbo and wanted to know what HP level would get me those times. Also, I am posting the rules pertaining to turbo size.
Turbos > Maximum size of a single true 94mm tip to tip turbo or smaller with the criteria shown below:
For a 94.0 mm / 3.701” - inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing.
Inlet housing is permitted a maximum inlet diameter of 3.781” where the leading edge of the compressor wheel meets the housing
For a 88.0 mm / 3.464” - inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing.
Inlet housing is permitted a maximum inlet diameter of 3.544” where the leading edge of the compressor wheel meets the housing
