View Full Version : Anyone wanna draw me up a wiring diagram?
porksoda
02-28-2008, 11:35 PM
Alright I'm finally getting all the stuff for my nitrous kit and it is starting to arrive so I need to start installing! Here is what I have:
HSW SI wet kit for LT1
HSW purge kit
HSW bottle heater kit
HSW switch plate for ashtray
HSW FPSS
HSW nitrous filter
Mallory 685 w/ MSD harness
NGK TR6's
Nitrous Outlet dual channel window switch
Nitrous Outlet spare tire bottle mount
Nitrous Outlet "V" purge w/ compression fitting
I want to use the Mallory as a regular ignition box during NA driving then have it pull timing when the system is activated. Everything came with instructions but I don't know if it changes with all the products I have. I also saw all the diagrams that Ray from nitrous outlet has on his Fquick but none of them really pertain to me. Any help is appreciated. Thanks
PAGregSS
02-29-2008, 08:31 AM
Look at nitrous wiring stickey at the top of this section.
Ray@Nitrous Outlet
02-29-2008, 11:11 AM
HSW purge kit
HSW FPSS
http://www.fquick.com/images/vehicles/full/382133881.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=33881)
http://www.fquick.com/images/vehicles/full/382146684.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=46684)
:confused:
porksoda
02-29-2008, 11:48 AM
Ok I was looking for one that had everything all in one diagram! Sorry.
Ray@Nitrous Outlet
02-29-2008, 12:04 PM
Use the first diagram to wire the nitrous system and the purge...the second is the heater and a remote opener.
They are seperate circuits anyways.
porksoda
02-29-2008, 12:09 PM
I don't have a bottle opener so i can just ignore that part correct? And for the ignition box I'm just gonna wire it like normal except for that one wire in the 1st diagram that goes to the solenoid?
BTW I left you feedback in the sponsor section!
Ray@Nitrous Outlet
02-29-2008, 12:10 PM
Correct...the retard wire from the 685 connects to the power wire going to the solenoids.
Thanks,
Ray
porksoda
03-02-2008, 10:55 PM
Ok and with the dual window switch I won't need a WOT switch correct since it has a built in TPS?
Ray@Nitrous Outlet
03-02-2008, 10:58 PM
correct
porksoda
03-02-2008, 10:59 PM
^^^Now thats service! Took all of 3 minutes from someone who wasn't even online when I posted the question.
Nitro Dave's Nitrous Outlet
03-02-2008, 11:08 PM
Thats what Nitrous Outlet is all about!!!:D
