NPB 11.15@121MPH 1.52 60FT Cam -only
NPB tonight first run 11.15@121mph 1.52 60ft ,yankin da front tire!!!Got a Formato retune at Race-Related on tues and put down 384 rwhp.Only changes since my last PB was a 85mm lid and zo6 maf ,hence the retune.Just goes to show you dont have to make big power to run good #"s,you just have to optimize your setup and put the power too the ground!!Previous best in similar weather was a 11.37@118mph ,not a bad pickup.
Car is def rollin out,it keeps gettin faster everytime i roll to the track.
I got suspension and tires, I'm a 6speed though. SO alittle harder to 60' like you. My best 60' was a 1.65' so far. Do you have a tubular k member and A-arms at all? You may have mentioned that already.I still have the factory kmember and a-arms, I was thinking of getting them just for the wieght savings.
I see you have the x4,how do u like it?Et streets are better than the radials for m6 cars from what i know.M6 hit the tires harder so the streets work better.Get urself some used welds and your times will def drop do to less unsprung weight,i would guess at least 1-2 tenths drop in e.t and a gain of 1-2mph in the 1/4.
Dave
