Fueling & Injection - 3 intank pumps
Big Bird WS6
02-29-2008, 03:48 PM
has anyone ever tried three intank pumps?
or run one intake 255 and one external one to equal three 255's?
Lonnies Performance
02-29-2008, 09:25 PM
I have one mocked up now, just waiting on someone that really needs one.
How much over 1000rwhp do you plan to be?
I figure I'll be ready to offer it to the first person to max out one of my twins.
Drew04GTO
03-01-2008, 12:13 AM
Hey Lonnie, quick question about these dual setups. Don't want to sound like an ass but something isn't adding up.
How are you getting past the fact that 255lph + 255lph with any kind of Y or T fitting does not equal to 510lph worth of flow. From my personal experiance I find that even with the best Y you're only going to get about an additional 60% worth of flow, and thats with a dual -6 in -12 out 12 degree Y fitting made by me. I start to get leary of using a 255lph pump after about 500whp so at ~410lph worth of flow how is your dual pump system good for 1000whp? What happens if one of these pumps fail? Obviously they're in parallel so my motor that's making 700+ hp that needed both fuel pumps is now running on one.... The only time I'll reccomend a dual pump setup is if someone is in a foreign country and doesn't have the parts available that we do. There's far too many high HP single pumps out there to run setups like this anymore IMO.
Once again, sorry for playing devil's advocate, I just want some real deal facts on dual pump systems.
Lonnies Performance
03-01-2008, 10:17 AM
You make some good points & I understand your concerns. I'll try to relate a few facts that I have from the the kits that I have built. FYI, I have built around 100 kits last year alone & have been doing these with Racetronix for over 4 years now. I need to check the total kits I have built over the years as the numbers will be surprising... especially without a single pump failure.
I have supported over 980rwhp on one of my dual pump setups with the limits not yet reached.
The flow testing on my dual assembly shows capability for around 1400hp flywheel. I recently had one of my kits flow tested at various voltages & pressures to support my claims. The pumps I use are slightly tweaked as well so your flows/pressures may differ. I will post proof of the HP limits when I find them in actual testing, since flow numbers only show theoretical HP capacity. I recently had a guy dyno test with 1 pump disconnected using my complete line/rail/regulator/pump kit & hit 700rwhp before his pressure dropped off. Obviously I do not recommend this & do not expect it to be doubled with 2 pumps running, but it is at least a point of reference.
The reason is that, due to flow losses through lines etc., no one is really capable of getting the full 255LPH from a pump at the engine. In theory a single standard 255 will support 800hp, but I've never seen that happen on a car.... maybe if it is hooked directly to the fuel rail it could. I have routinely seen 550rwhp (with stable pressure) on a single replacement pump kit though stock lines, & an approx 75 additional HP with better fuel lines, regulator, rails etc. The other reason is as you reach the upper limits of pump flow the pressure drops off quickly... you are really not using all the flow, but dealing with a pressure drop where the pump cannot support your pressure requirements. If you run lower base pressure, you can support more power on the same pump.
External pumps require pump controllers to prevent heating of the fuel & pump cavitation on the street. They are noisy as well. My goal is to provide a convenient & relatively economical means to supply fuel. If I had a race only car, I would run an external pump & a fuel cell.
Also, modifying a plastic tank for external fittings is not the safest thing to do. These are engineered to meet certain safety requirements & drilling them can lead to stress risers which can cause a tank fracture during an accident. I definitely do not want to be in a 16gal puddle of burning fuel during an accident. For liability reasons, I will not modify a fuel tank & cannot recommend that anyone do this.
Sumped metal tanks are definitely easier, but modifying these must account for the rusting of the welded area where it is modified. I do not know of anyone re-galvanizing their tanks after modification either. Again on a street car, this can cause long term durability problems due to alcohols & fuel additives.
Trying to mount an external pump below the fuel level in the tank is rather hard with a stock tank & how low most cars are today. Mounting it above the fuel level is a potential problem with priming & also due to the fact that externals do not pull fuel well.... all considerations for long term durability.
As for failure potential....
Running an external pump on the street with a controller still has 2 points of failure... the pump & the controller. A failed controller could leave you running at half pump capacity or stranded on the side of the road. This is no different than the 2 pumps that I have. I have never had a pump failure to date, but it could happen, just as the many here that have complaied of the external pump failures on the street. Nothing is fool proof & therefore the reason to always watch your fuel pressure gauge.
As far as 3 pumps, this is probably a little extreme, but still possible. There are a few triple setups for turbo vipers out there currently.
You do have valid ideas & concerns, but my attempt here is to provide an easy, simple & quite method of supporting serious street HP without the headaches of external pumps, controllers & tank modifications. This works great for those that want their car to look & sound more stock than is it. I'd rather hear my engine or stereo than the pump running.
Thanks for your interest & your questions are always welcome. Your thoughts were professionally expressed & I value your opinion. If you would like to discuss this further, please give me a call... I talk much better than I type. Also, I'm an engineer so I get into the technical aspects of this stuff.
eb02z06
03-01-2008, 11:07 AM
I'll let you know this coming week! Doing my car with a 402-it's at 830@5000 only and we figure it should be 950+@6500, then we have a TTix car that should hit 1000 rwhp too, next a 427-this one is getting the big F1R-I'm on a F1A and if I can hit 950+ this car should make 1000+.
But so far LONNIES DUAL'S KICK ASS!!!!! It's such a nice clean setup with a painless install. BTW-lonnie-i put the fule filter in the fenderwell and know the lines are far away from the exhaust-I'll post pics when I get around to it.
Drew04GTO
03-01-2008, 12:26 PM
Sweet, thanks for clearing that up Lonnie. Glad to see you've done plenty of research into this and am quite confident in your setups after reading what you've posted. If all goes well with my employer I might be transfering up to Pittsburgh in less than a year, nice knowing I'll already have a reputable shop to go to when I get up there.
Lonnies Performance
03-01-2008, 08:20 PM
eb02z06, let me know.... I'm anxious to find the limits. I've even made some improvements since I made the first one for you. Send me some pics, I'd like to see your install.
I also provide tech support for my customers, so I'm only a call away (night & weekends as well) if you have questions during the install.
Drew, if you have additional questions, look me up, I'll be glad to help you out.
Andy02Z
03-01-2008, 08:40 PM
Im building a lsx 427 with a s91 and plan to max it out. What do you recommend?
Andy02Z
03-01-2008, 08:50 PM
Tiago pushed his T56, dual intank setup to 1090rwhp before running out of fuel.
Lonnies Performance
03-02-2008, 09:58 AM
That is good to hear, but I am not sure he was using my kit. 1090 is a serious number that most will never achieve in a street application, so I feel pretty confident that I can provide a suitable setup for over 99% of the people out there.
If anyone is building their car, please contact me before starting to buy any fuel components, this way I can work with you to be sure all bases are covered in regards to injectors, regulators etc. It seems that about 25% of the people that call me already bought a few pieces that they shouldn't have.
Andy02Z
03-02-2008, 11:14 AM
No, I think he did his own twin 255 setup.
I'll call you soon to discuss my setup.
Big Bird WS6
03-02-2008, 06:10 PM
sent you pm
Z284U2TRY
03-02-2008, 06:39 PM
Plenty of cars around here running 1000 plus on twin in tank pumps.
rcsfastmonte
03-02-2008, 07:58 PM
I am running his twin in tank kit love it ,was and is one of the best setups i have seen! ill test it this year adding a 408 with bigger turbos to my last years 10 second GTO..
Lonnies Performance
03-02-2008, 08:31 PM
Thanks for the kind words & glad you are happy with it.
SSilverSSurfer
03-02-2008, 10:05 PM
contact Tiago and MECHAM. they both are running 3 intank pumps. ive seen tiagos personally and hes using his eBOOST2 aux to kick on his 3rd pump. i remember him having some problems with it but i think he got it taken care of. his set up consists of 427LSX and twin TC76MPS turbos
Nasty N8
03-04-2008, 11:10 AM
We have also sold about 100 of Lonnies dual setups with our Street systems and have never had a single pump failure...Nor one maxed that I know of. These are very precise and assembled for a factory function and finish only reason I use them for our systems they are the best available.
Nate
taner
07-12-2008, 06:50 PM
thanks for fielding my call late on a sat. afternoon! I appreciate the tip on dealing directly with racetronix, as i am in canada, as is Racetronix.
Jake@EPP
07-12-2008, 07:14 PM
Nothing but good dealings with Lonnie and Nate here, highest we have done with his twin pump in a c5 is 857rwhp on a TT car (mustang dyno as well).
I do like the twin walbros due to how quiet they are and affordable.
Im not sold on doing 3, just due to your adding yet another variable in the fuel system.
I belive if you need that extra hp worth of fuel, get a weldon with a dial-a-flow and call it a day. The supra/viper guys run 3 pumps with good luck, but it would kill me to hear someone burning a motor due to a $115 pump dieing.
Lonnies Performance
07-12-2008, 08:23 PM
Taner,
You should have said who you were..... I admire your work on that car & followed some of your progress/videos online.
If I knew who you were, I would not have asked you all the basic questions.
Feel free to call me anytime if you have additional questions. I'm usually at it 9:00am - 11:00pm eastern time.
Nasty N8
07-15-2008, 10:08 AM
Jake I think me an Lonnie agree with you we have discussed it several times and had customers asking about doing it and we just set them up with one of my race tank kits.
Nate
Tricked-Out-Toy
07-15-2008, 11:01 AM
Do you have any pics of the 3 pump setup? ill never need more than 2 but just to say "ya Ive got three pumps" is pretty badass :)
Jake@EPP
07-15-2008, 05:01 PM
Nate
Yep, best way i see. Hell we even have a 800hp Caddilac Cts-v with a Magnafuel 4303 pump, its a hell of a car to have a "full race" pump on.
Racetronix
07-16-2008, 10:20 PM
We have a dealer who makes billet tripple in-tank fuel pump senders for Supras. The tripple-pumper harness we make is custom order.
stevieturbo
07-21-2008, 06:30 PM
I beliave MM was running 3 pumps a while back, and as above, the Supra guys do it.
I recently seen that billet adaptor, stunning !!!
veee8
07-21-2008, 06:42 PM
I am building a 3 pump setup as we speak. After talking with MM and Tiago, figuring out the triggers was the easy part. 2md triggered through BS3, third staged through Eboost2. I use a metal LT1 tank and upper sending unit. The lower is a custom billet piece from the same guys making the Viper triple kits. Uses the factory gauge sending unit. Removed the factory feed and return, replaced with -10 and -8 bulkhead style fittings. Uses 3 Racetronix 255's. Pics will be up in a couple of weeks.
MIGHTYMOUSE
07-22-2008, 08:57 AM
i still havent run out of fuel so i still havent done anything
my options are a third walbro or take one walbro out and replace with a bosch 0420 that i all ready have, just need that expensive ass sock filter for it.
Tiago
07-22-2008, 09:43 AM
mine is working excellent so far, haven't turned it up past 1100 rw yet, but thats where 2 pumps failed and now it is solid.
taner
08-03-2008, 03:06 AM
Taner,
i hope you are around later today...at a decent time that is..... pm about to be sent! lol!!!!
and thanks for the compliment! more to come this year :) i really appreciated you taking the time, and it doesn't matter who i am, i am just another speed addict :D
