Beating on the a GTO - Quick Question
Im fairly new to the LS1 (04 GTO) and was wondering how much of a beating can the car take? Its got 21K miles and is stock...(just bought it!) I never beat on the car or tranny because of fear of "Beating" on the car and lowering the live of the car.
When i say beating on it I mean pushing the pedal past 75% throttle and coming close to red line. No drifting or pealing out . Of course i understand what is beating on the tranny is and what it can cause so I am not worried about that.
For example, at a stop light and lighting the car up though first to third. (M6)
Obviously doing this often will cause damage over time. (Duh) But my question is, the car is engineered to take a beating and maintain itself with out causing problems? I just have a power house and feel a little guilty if the car is opened up to much. What do you guys think?
i have a 06 and i beat it to the ground.. multiple track runs a week, weekly roll races ect... i push her... she holds. keep her in tip top shape... she will stay strong for you... my clutch is the only burden
Ha good to hear. Sometimes when shifting into second, it will grind even though the clutch is 75% engaged. I use normal shifting and once in a while if you seem to be at the right speed and try to go into second it will grind and not allow you to enter the gate. Is that the "1st to 4th" deal? Whenever that is on it usually will not allow you to even come close to second but i could be wrong. What does this sound like?
whats going on cool... yeah i wouldnt worry to much about it. like everyone said about normal wear and tear and your clutch but watch the missed gear at high rpms.. i wouldnt push the car all the time but you can still have fun with it
I've got an '04 GTO that I bought used at 23k miles. I'm close to stock power (Only K&N CAI and tune), I've gone to the track about once a quarter since Summer '06, but I run it pretty hard on the street. I burn out (more so when I bought the car) and drift in it (not the hardcore stuff, but getting sideways never gets old). I've got 48k on it now (as it's my DD) and I've had no problems *knocks on wood* with the car. The stock clutch still holds up well and has never slipped. The only thing is that I avg 12 mpg on the street and go through a pair of (rear) tires every 6 months. I change the oil every 3k-5k miles (depending on how much interstate traveling I did). Only thing I haven't done, but will do shortly, is change the other fluids. I'm holding off on the coolant as when I get a CAM next year it will be replaced. I've already changed the rear diff fluid as well. All that is left now is the manual tranny fluid, the clutch fluid and the brake fluid.
Oh, and I have got to change the air in my tires as well :-P
