408 and F1A procharger
Old 02-29-2008, 08:44 PM
ws6102488's Avatar
Default 408 and F1A procharger
Wat kind of power should i expect. The 408 is 9 to 1 dart 225s custom grind cam all the good stuff. Just wondering kind of power to expect the car made 456rwhp on motor.
Old 02-29-2008, 08:49 PM
venom ws7's Avatar
How much boost???
What trans ?? and rear???
Jake@EPP's Avatar
Gauging from past results, about 14psi or so is right around the 800 level with AFR heads and 6spd trans. Depending on how big the cam is , and how well the combo works, it should be anywhere from 700-900 depending on pulley.
Old 02-29-2008, 09:35 PM
ws6102488's Avatar
Its a rpm level 5 trans. the car still has stock rear. Im looken to atleast push around 12 to 14 psi
Old 03-01-2008, 01:22 AM
eb02z06's Avatar
I'm at 730rwhp@5000 rpm and 10 psi-I'm expecting around 950+@6700-7000. This is through a auto and pump gas. The 730 was just dialing it in yet-still have to throw lots of timing at it! Hopefully I'll get the belt slip issues sorted out this weekend.
Old 03-01-2008, 04:05 AM
EPP
EPP's Avatar
Check out this build we just finished at this link.
http://www.exoticperformanceplus.com...Car.php?car=29 Bob
Old 03-01-2008, 09:03 AM
Websy21's Avatar
I've seen several guys post on here with that combo making b/w 750-800rwhp
Old 03-01-2008, 09:45 AM
ws6102488's Avatar
how long u guys guess rear end will last? And wat kinda of track times should i expect? The car runs 7.0s to 7.20s on motor at 96mph with 1.5 60ft
Old 03-01-2008, 10:42 AM
SVC707's Avatar
with my d kit. somewhere between 9-10 psi pump gas 91 octane im at 739ho. so depends on like said above how well your motor is built. im running a larger cam 24x/25x forgot what it was unless i dig through posts
Old 03-01-2008, 11:33 PM
ws6102488's Avatar
wat kinda of times should i run i run 7.0s on motor at 96 now how is the charger goin to pick me up
Old 03-02-2008, 02:26 AM
Hawk108's Avatar
Haha I think it will last for a long time. . . .as long as you keep it under 2,000 rpm at ALL times
sounds a sick setup youve got there.
Old 03-02-2008, 10:12 AM
EPP
EPP's Avatar
I've heard of guys breaking the 10 bolt rear just pulling the car out of the garage. With a six speed, expect to need a tow truck the first time at the track. As far as dragstrip times go, you can add 150 rwhp and not significantly affect your 1/4 mile times if your suspension is still fairly stock. Wheelspin and mph would go up, but without hooking don't expect a huge drop in 1/4 mile times.
This list may help you out some.
http://www.exoticperformanceplus.com....html?item=540 Bob
Old 03-02-2008, 10:41 AM
lmt0705's Avatar
hahahahahaha!!! been there done that, dont go to the track without a diff in the thing, last year I got 2 passes in then I sheared the bolts off the ring gear on mine and my buddy who has a mild bolt on TA broke his. we had tandom flatbeads trailor us 100 miles back to my shop. GOOD TIMES
Old 03-02-2008, 10:42 AM
lmt0705's Avatar
I stepped up to a 9in. from Bob at EPP and couldent be happier
Old 03-02-2008, 12:05 PM
ws6102488's Avatar
It still holding now pulling the wheels off ground running 7.0s on motor i cant beleive it. Im going to run it until it breaks.
Old 03-03-2008, 05:12 AM
EPP
EPP's Avatar
Thumbs up
Thanks, I appreciate it! Bob
Old 03-03-2008, 12:17 PM
transamfreak01's Avatar
how "streetable" would an application like that be? would you be able to take it out on the weekends at all?
Old 03-03-2008, 02:03 PM
Marz's Avatar
Ya you should be fine driving it around ..I will be driving mine to the track about 30 min drive and all over the place to cruise
Old 03-03-2008, 02:57 PM
PhillyLS1's Avatar
Did your car come together yet?
Old 03-03-2008, 07:31 PM
ws6102488's Avatar
Is the kit pretty simple to install? Just wondering i would like to try and do it myself and wondering how hard it is? The kit has front mount and and the 9 inch spal fan. Wat parts will i have to remove?
Quick Reply: 408 and F1A procharger
