Slippy slippy clutch
Old 02-29-2008, 09:16 PM
myws61's Avatar
Unhappy Slippy slippy clutch
Damn, ok so my clutch is slipping, just started though. It holds for daily driver, but if i roll on it or wot, its pretty bad feeling. So heres the question, can I use break parts cleaner on it, and will that work. I have heard some people say it works, and some have laughed. So I figured I will get on the interweb and ask the pros!
Its a spec stage 3+, and Im pretty sure its oil from my oil pan. I wll replace the oil pan gasket, but do you guys think a little break parts cleaner will work.
Jeff
Old 03-01-2008, 12:48 AM
wrencher
wrencher's Avatar
I doubt it once it get in the friction material your pretty much SOL.
Sure it's getting oil on it though?
That would be alot of work just to clean it IMO
Old 03-03-2008, 01:00 AM
myws61's Avatar
hmm, anyone else have any thoughts?
Old 03-03-2008, 12:36 PM
SPEC-01's Avatar
WS6...brake cleaner can be used to clean a CSM (Carbon-Semi-Metallic) disc without issue. Pull the assembly; clean the disc, plate, and flywheel, and while you are at check the wear by Mic'ing the disc thickness. Let me know what you find and feel free to send pics of the assembly if you want me to take a look. Thanks!
Old 03-03-2008, 06:32 PM
Hugger Z's Avatar
I had a similar issue. Put a new LS7 clutch in the car and a month later the crank freeze plug started leaking all over my new clutch. Pulled it apart and cleaned the friction REALLY well with brake cleaner for a few days. Reassembled after it was clean and the new plug was in. And no issues.
Quick Reply: Slippy slippy clutch
