urgent help!!!!!
I assume you have already checked all the basics - electrical connections, grounds, etc.
There's 3 things an engine needs to run: air, fuel, and spark. You may be getting all 3, but you are obviously not getting enough of one of them to keep it running.
Air is almost never the problem, so you need to look at fuel and spark. If you have a stock coil, it's easy enough to spend 10 minutes to swap it out.
