Blots to transmission to bellhousing / bellhousing to block
Old 03-01-2008, 01:27 PM
jamiesls1's Avatar
Default Bolts to transmission to bellhousing / bellhousing to block
Does anyone know the size of the bolts that go from the transmission to the bellhousing and from the bellhousing into the block?
Old 03-02-2008, 09:03 AM
Fran D's Avatar
Bell to block, M12X1.75X45
Trans to bell, M10X1.5X40
Old 03-02-2008, 02:04 PM
Moderator
davered00ss's Avatar
www.installuniversity.com they have a write up on installing a clutch w/ pic's.
10mm
13mm.
Old 03-03-2008, 04:54 PM
jamiesls1's Avatar
Thanks a bunch guys
Old 07-26-2008, 11:31 AM
Ford_Assassin's Avatar
Does the same go with the A4 as the T-56?
Thanks!!
Old 07-26-2008, 02:03 PM
Fran D's Avatar
Thanks!!
As far as I know. I haven't worked on an A4, but I can't imagine why it wouldn't bolt up to the block the same way (like the GMs of old). I don't know if it needs longer or shorter bolts, though. You may try your question in the auto forum.
Old 07-26-2008, 04:17 PM
Okay, I can tell you that the block bolt holes are NOT M12's (too big on my 5.3). I don't have any M10's lying around, by I am sure they are the correct ones.
