95 Z28 Engine Misfire
I have a 95 Z28 that seems to be having a terrible misfire. It happens horribly when the car warms up. It's smooth till you try to floor it from about 40 mph then it stumbles and shakes until you let off the gas. Sometimes it will keep stumbling after you let up. Also, it has a horrible backfire. My mechanic seems to think there is a performance cam in it, (I am unsure of the history on the car, but it runs rich too). I think it might need tuning, I just wanted to get some opinions from some of you guys before I do.
Are you plug wires arcing on anything at all? Like exhaust mani/headers(depending on what you have) or maybe a heat sheild? Make sure all plug wires are tight and away from those sorts of things. Start it up and look under the hood at the wires and see if you see any flashing/spark.
Horrible backfire may be from a timing issue. But do remember Most LT1's are prone to backfiring, its just a thing they do. Mine never did it, i would say maybe 50% do. Im sure others will chime in on that.
Mine acted like this with a bad O2 sensor, but it also threw an O2 sensor code, so it may be worth checking! The thing that sounds exactly like mine is it ran ok until you tried to give it some gas, then it would sputter and try to die.
