Car sits 3/4 inch higher with dana 60 rear
Old 03-01-2008, 06:14 PM
00camaro ss's Avatar
Default Car sits 3/4 inch higher with dana 60 rear
Like my title says since my strange dana 60 install the rear of my car sits 3/4 inch higher in the rear than it does in the front. I still have stock springs, panhard bar and torque arm on the car. Any ideas would be appreciated.
Old 03-01-2008, 06:18 PM
badazz99ta's Avatar
take off the rear spring isolator. it should be good for about a 1/2".
Old 03-01-2008, 06:28 PM
Kleeborp the Moderator™
MeentSS02's Avatar
It is to be expected with a rear that big. Removing the rubber isolator would be first on the list of things to do if you don't plan on changing the springs on all four corners with those of the lowering variety.
Old 03-01-2008, 08:38 PM
Thanks for the input, I'll try it tomarrow.
Old 03-01-2008, 08:50 PM
pozesd99''s Avatar
pm sent
Old 03-01-2008, 09:21 PM
kny3twalker's Avatar
whats the pm about? I have a 12 bolt and have the same problem. I am thinking about doing the heater hose mod very soon
Old 03-01-2008, 09:35 PM
pozesd99''s Avatar
mine is getting the dana s60 installed right now and im worried lol i have eiback sportlines and would like to know how the rear will sit
Old 03-02-2008, 07:39 PM
bad6as's Avatar
the axle tubes are bigger then stock thats why it sits higher
Old 03-14-2008, 08:04 PM
wrd1972's Avatar
Trim the coil springs
Quick Reply: Car sits 3/4 inch higher with dana 60 rear
