Panhard Bar
Old 03-01-2008, 06:46 PM
kicksZ28's Avatar
Default Panhard Bar
My car is not lowered and I do not intend to lower it. It has stock suspension and i want to replace the panhard. Do i really need the adjustable type or will the non adjustable work fine? Thanks
Old 03-01-2008, 07:15 PM
jetlag's Avatar
An adjustable panhard bar is never a bad thing...go ahead and spend a couple extra bucks and get the double-adjustable one.
Old 03-01-2008, 07:23 PM
Viper's Avatar
I agree, that way if you ever need it you have it. Plus some cars are not centered from the factory; not something you can always see visually (we're talking 1/4" here).
Old 03-02-2008, 12:15 PM
kicksZ28's Avatar
Well, i just measured my cars rear tires at the fender and the rear is not centered so now i know i will get the adjustable panhard. Looking at best prices and quality before i order. I have found a UMI from a non sponsor with free shipping. ??? Thanks
Old 03-02-2008, 04:01 PM
jetlag's Avatar
There are sponsors that offer free shipping also......
Old 03-02-2008, 04:24 PM
coolformula's Avatar
One of the best bang for the buck items for the car almost seems like you put an IRS in it lol, well not that good, but its really great for the small amount of money they cost.
Old 03-03-2008, 06:17 PM
sidewayz28's Avatar
adjustable for sure, i messed up and bought an non adj. one.. oh well
Old 03-03-2008, 06:40 PM
Moderator
davered00ss's Avatar
Get adjustable. Just incase you change your mind in thefuture. I have a non adjustable UMI, and I wish I had gotten the adjustable one.
Old 03-03-2008, 07:02 PM
koolaid_kid's Avatar
I went with the single adjustable UMI rod/poly. It corrected my rear alignment, which was off by about 13/16" toward the passenger's side. Once it is adjusted, you should not need to adjust it again, unless you make changes. JMO.
Old 03-03-2008, 10:17 PM
badazz99ta's Avatar
yeah man, get an adjustable one. i just got a umi on car adj. one, but i havent installed it yet. cant wait though.
Old 03-04-2008, 03:37 PM
INMY01TA's Avatar
I'm not lowered either and I went with the Spohn double rod ended phb. No regrets.
Old 03-04-2008, 05:21 PM
kicksZ28's Avatar
thanks for the input.
Old 03-05-2008, 03:25 AM
waldershrek's Avatar
UMI all the way! I know several sponsors offer free shipping or $1 shipping
Old 03-05-2008, 03:53 AM
Datzneat's Avatar
Adj, UMI, bynuspeed, w/free shipping, and call it a day.
Old 03-05-2008, 04:55 PM
INMY01TA's Avatar
Here's a pic:
Old 03-06-2008, 10:17 AM
z28bryan's Avatar
Why would anyone get a non adjustable PHB over an adjustable one.
I was impressed with the UMI single adjustable PHB since it has that double threaded piece that allows you to adjust without removing the bar. I should have gotten one of those.
Old 03-06-2008, 05:22 PM
StolenRedCamaro's Avatar
what are the benefits to be had with a rod end vs a poly end?
Old 03-07-2008, 09:40 AM
z28bryan's Avatar
Poly will probably transmit less noise than rod end. How much noise I can't say. It may be too minimal to notice. I didn't notice, but I also did a lot more modifications at the same time as the PHB. I have a dual rod end. I would get a dual rod end or a single rod end at least.
Stock rubber bushings would probably transmit less noise than poly.
Old 03-08-2008, 10:45 AM
SOMbitch's Avatar
UMI double here. Quality piece.
Quick Reply: Panhard Bar
