Loud "POP" under hard accel
Old 03-02-2008, 12:01 AM
nomoneyz's Avatar
Default Loud "POP" under hard accel
Hey guys, I noticed this problem the other day and tonight, when I punch it in first at around 4 grand I hear this loud POP from the driverside of the car. I'm not sure what it could be the car seems to studder for just a brief half second when it happens. I'm not showing an SES light. I'll scan it tomorrow to see if I'm throwing a code.
A little info on the car.
95 Z28, CAI, Elbow, air foil, Cutout, fully built trans with 3200 stall.
The plugs haven't been changed in probably 8-12 months same with the wires. I'm waiting to do the plugs till next weekend when I install the LT's
Thanks in advance
Old 03-02-2008, 12:16 AM
sweet-94z28's Avatar
I would do your tune up and see what happens
Old 03-02-2008, 12:34 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
It could just be a little unburnt fuel in the exhaust. My formula would make some pops on decel after a hard run. It was nothing too loud though.
Old 03-02-2008, 04:26 PM
97lt1z28's Avatar
I had same prop a while ago.....it was my plu wired burnt up
Old 03-02-2008, 04:32 PM
z2896's Avatar
most likely you have an exhaust leak, i would start there first. does it pop when u rev it up in neutral?
Old 03-02-2008, 06:14 PM
nomoneyz's Avatar
I'm not sure if it does it in neutral. When it happens, it sounds like something is going break. I'm about to scan it right now.
EDIT- It doesn't do it in neutral, and I just went to go see if it would do it again and it didnt make that sound now. I do have a couple of exhaust leaks though. I'll check my wires and stuff. Think it could be the opti, its original with 130,xxx miles on it.
Old 03-03-2008, 12:21 PM
Formula96's Avatar
Transmission mount.... Trust me, i have replaced mine 3 times. A good way to tell is to pop the hood, have someone watch the motor, and brake stall it in first, there will be a lot of movement if it is the tranny mount...
Old 03-03-2008, 02:58 PM
nomoneyz's Avatar
Its deffinatley not the tranny mount. I've replaced mine alot also but this one is still good. I'm leaning toward my plugs and wires. There really old. Sucks that I have to drive it until the weekend like this though. Damn work till dark and don't have garage.
Quick Reply: Loud "POP" under hard accel
