STEEPSS
03-02-2008, 02:24 AM
i have a loud whine / squeak when my A/C is off. as soon as i turn on the a/c, the squeak goes away. i'm quite sure it's my clutch on the compressor. i was just wondering if anyone has advice on what to do to fix this.
waiting2bl33d
03-02-2008, 09:04 AM
are you sure that it is the a/c clutch?
if you are i would buy a used compressor off the site if you can't find a new clutch.
i would also make sure the idlers and belt tension pulley that is on the a/c system just to make sure thats not your problem
snake charmer
03-03-2008, 11:46 PM
since the ac uses its own belt take it off and run the engine just to make sure . most of the time it is the ac tensioner .
