Anyone run a LuK progold setup w/ aluminum flywheel
Old 03-02-2008, 04:10 AM
97C5driver's Avatar
Default Anyone run a LuK progold setup w/ aluminum flywheel
I just got this setup installed and wondering how it will hold up. My C5 is basically stock beside exhaust/intake so there won't be any rediculous power to it or any drag racing.
the stock type clutch i just replaced lasted about 40k with one auto-x, a few burnouts, and a whole lot of bumper to bumper traffic.
If you're running the same, how do you like the setup?
Old 03-06-2008, 10:27 AM
winger4800's Avatar
I have the same setup...I love how it revs up quicker with the aluminum wheel...
but I just got a cam and now it cant take the abuse so I need to upgrade....
Old 03-06-2008, 10:30 AM
Kleeborp the Moderator™
MeentSS02's Avatar
From the research I did back in the day, it is nothing more than a standard LS6 clutch attached to an aluminum flywheel. That's what steered me away from it...
Old 03-06-2008, 11:08 AM
winger4800's Avatar
YUP thats right......
Old 03-06-2008, 02:17 PM
01sschris's Avatar
I thought Luk made a lot, if not all, of the clutches for GM. Do they not make the LS6 and LS7 clutches?? I have read that info somewhere on the internet. If I've been misled, does anyone happen to know who makes the LS7 clutch and/or flywheel for GM. BTW, LuK also offers a kit w/ a steel flywheel
Chris
Old 03-06-2008, 02:23 PM
MeentSS02's Avatar
Chris
You have not been misled. Luk does indeed make the LS6/LS7 clutches, as well as a ton of other different clutches for different manufacturers. I wonder if they are behind the LS9 twin disk...
Old 03-06-2008, 06:54 PM
DAVESS02's Avatar
I bought a Luk Pro Gold for an older chevy, pn#04-902. Its a 12" PP non-adjustable type. Installed it with a ceramic 6 puck 11 7/16" disk I had made up at the local clutch shop. As soon as I get my driveshaft I'll post how it works/holds power. The thing is that Luk wont sell this PP with a 26 spline disk. They could very easy though. The Pro gold friction disk that comes with the kit is a 10 spline. The spline hub is detachable from the disk. The Luk viper clutch disk uses the same type of removable center spline hub only with 26 splines. Of course I called Luk and the tech support acted like I was the clutch anti-christ for asking if I could purchase the center piece so thats why I had to use the puck.
Old 03-06-2008, 07:01 PM
D-Webz's Avatar
I have a luk pro gold setup in my TA and it works quit well for my setup.
Old 03-08-2008, 12:50 PM
DAVESS02's Avatar
So far this set up is great. I had another puck type disk with a 2002 stock PP and it chattered quite a bit. This is the same disk material only with a billet flywheel and the Luk PP and it doesnt chatter at all! I'm very impressed. Now if it holds power, it'll get 2 thumbs up.
FYI, the car is a 346 with AFR 225's, 228/230 on 110, M6 faceplated trans, 3:70 gears in a 9" with a 35 spline locker.
Old 03-08-2008, 01:52 PM
NemeSS's Avatar
ive always had good luck with luk clutches with mild power
street cars, not 7k rpm clutch dumps of drifting,
but with 400rwhp dd car
Old 06-08-2009, 02:40 PM
bww3588's Avatar
i called the ppl who make Luk clutches, and they said the pro gold series they make for 98-02 F-bodies is rated to hold 550ft-lbs.
Quick Reply: Anyone run a LuK progold setup w/ aluminum flywheel
