not sure why 6.0L/L92 head motor won't start
6.0L iron block, L92 heads from SLP, truck coils, custom harness and pcm. ricks stainless tank, double pass radiator......in a 68 rs camaro. just got it together, put coolant in the radiator after installing hoses, and overflow tank.....turned on key, adjusted pressure to 60lbs........motor just turns over and over. pulled a plug, and tried starting it to look for spark. doesn't look like it has spark. what do i do?
what computer?
02' ls1 style, 24tooth reluctor with cable throttle. I'm wondering if the place i'm getting key on, or ignition power is correct. from the fuse panel to a relay excited by keyon. but, does the power stay hot when cranking? or does that matter?
I found that bleeding the air out of the fuel rail via the Schraeder valve was key during the initial start-up following a replacement of the fuel system. Once that happened, it was beautiful noise.
Good luck.
Good luck.
keystart hot wire.
fire in the hole, it started......yay. my keyon start wire was in the wrong place. once i moved the wire.....it was instant bliss. now i just need to burp the air out of engine. any suggestions?
