Help please, Master or Slave?
Old 03-02-2008, 06:26 PM
superslowjoe's Avatar
Default Help please, Master or Slave?
Driving normal, shift to second, no pressure in the clutch, Car still works, but the Mcleod is slipping bad!
Bought a new disc, and a slave, pressure plate resurfaced.
Car still engages all the way to the top of my release after new parts installed. I have a Mcleod Adjustable, did my master take a dump? The clutch just doesnt feel right, pressure is gone. I thought it was the slave, had all this stuff replaced and still not feeling right??
Old 03-02-2008, 06:54 PM
blue98Z's Avatar
This may interest you:
https://ls1tech.com/forums/manual-transmission/870267-fix-those-have-mcleod-master-cylinder.html
Old 03-03-2008, 06:04 AM
DarkJuggalo's Avatar
dont feel bad i did the opposite, i did master then slave went 2 days later ;D
Old 03-03-2008, 08:02 AM
wrencher
wrencher's Avatar
Hows the adjustment on the master?
You need to have a little free play in the pedal, just a tad.
That way you know the clutch will be fully released.
Old 03-03-2008, 06:58 PM
Havent messed with the master yet, crappy weather. My question is everything was working perfect then one shift and WHAM, clutch dis-engages all the way at the top, change all the parts and it still does it. It feels like there is no pressure in it at all. I am wondering if the pressure plate is bad. It looked fine when the shop had it out, no bent fingers and no hot spots on the PP.
Old 03-03-2008, 07:07 PM
wrencher
wrencher's Avatar
well in that case it does sound like a master. The McLeods have been known to cause them.You may at the very least need to bleed it, or you mught need to rebuild the master.
