Shifter issue.
Old 03-03-2008, 04:23 PM
The_Wretched's Avatar
Default Shifter issue.
Shifter is having difficulty slipping into first. Sometimes it gets kind of stuck... and you have to basically shove into gear.
its a factory hurst shifter.
Old 03-03-2008, 04:36 PM
LemonTree's Avatar
How is your clutch? How old? Checked fluids? A little more info would help for better diagnoses.
Old 03-03-2008, 05:15 PM
TheLS1Kid's Avatar
Do you have a short stick?
Those factory hurst shifters are pretty stiff when you use it with a short stick because you have no leverage. Thats how my brothers WS6 is.
Old 03-03-2008, 05:52 PM
no its pretty tall. havent checked fluids. not sure where that is located.
Old 03-04-2008, 09:52 PM
sdm1234's Avatar
a clutch that's on its way out would cause this. low/old fluid could do this, as well. hopefully it's not a synchro (you would get a chirp if it was).
Old 03-04-2008, 09:55 PM
XplicitPerformance's Avatar
I have this problem sometimes too. The car is said to have a rather new Centerforce clutch. I thought this was maybe just the way it is. The fluid level is fine.
Old 03-04-2008, 10:00 PM
sdm1234's Avatar
check your hydraulic system, then.
Quick Reply: Shifter issue.
