Western Members CA, AZ, NV, UT, CO, NM, HI
when i turn my steering wheel it sounds like a dying whale! need help
Old 03-04-2008, 12:05 AM
maverick32's Avatar
Default when i turn my steering wheel it sounds like a dying whale! need help
hey what up fellas. well this is my situation about a year ago my power steering pump went out so it was rebuilt in order to save some money cuz i didnt have enough for a brand new one. along with that my rack and pinion was rebuilt as well. so now a year ago i am having the same problem. when i turn my wheel it sounds like a whale is stuck inside my hood and it seems like my power steering pump is leaking. what advice can you give me? do you guys think its that power steering cooler thing. i apologize i know very little about this.
Old 03-04-2008, 01:00 AM
ae13291's Avatar
if you have the cooler, check inside the radiator! see if the power steering fluid is mixing in with the coolent or vise versa check your power steering for coolent! also a main possibility is that it can be low! or open the power steering cap and have somebody turn the steering wheel slowly, look for foaming of the fluid! if its foaming its getting air into the system from somewhere, could be the o ring in the pump or the rack!
Old 03-04-2008, 01:07 AM
maverick32's Avatar
how would i know if i have a cooler? where do i check. i know that it cant be low cuz i am careful with my fluids and i check them every other week or so. i do notice when i open the PS cap air gets pushed out like if its under pressure inside.
Old 03-04-2008, 01:20 AM
ae13291's Avatar
its normal that its under a bit pressure! if you see a metel peice of pipe on the top radiator hose then you have the cooler! but just double check the fluid level! you can never be sure! and do the thing like i said, turning the steering wheel to check for foam!
Old 03-04-2008, 01:32 AM
maverick32's Avatar
so to check to see if i have the cooler i just open up my radiator cap and the metal piece of pipe should be there?
Old 03-04-2008, 01:44 AM
ae13291's Avatar
ok hold on i i will try to find a pic for you!
Old 03-04-2008, 01:46 AM
maverick32's Avatar
lol..ha thanks man.
Old 03-04-2008, 01:48 AM
ae13291's Avatar
https://ls1tech.com/forums/showthrea...ooler+steering
ok look in this thread, scroll down and you will see it! if u see that metal thing on your radiator hose then you have a factory cooler! let me know!
Old 03-04-2008, 01:53 PM
junkindatrunkmx6's Avatar
What kind of PS Fluid are you using? jw.
Old 03-04-2008, 02:38 PM
m6ttop's Avatar
dying whale!LMAO sorry
Quick Reply: when i turn my steering wheel it sounds like a dying whale! need help
