cleaning up un der my hood ......
OWN3D BY MY PROF!
Just get in there and start ripping stuff out. For the EGR/Air if you don't have race headers you'll need block off plates. You'll need one for the back of the intake manifold period. I used the stock one, whacked the tube out of it, cut the tube up, flattened it, and welded it over the hole. !ABS you'll need a proportioning valve. You can reroute the fuel lines through the back of the fender. All you'll need is a 2 inch grommet and some zip ties. That's all I can think of off the top of my head. LALT1 has a lot of good info in his fuel line thread.
yeah you can take out the emissions...air and egr...
if its not a daily driver you can rip out the a/c
there is the wire hide mod where you take the wires running down the passenger side and hide them under the shock tower. there is the mod to relocate the fuel line.
also you can relocate the battery to your rear trunk.
