belt flew off again
Old 03-04-2008, 07:07 PM
Powder96SS's Avatar
Default belt flew off again
last night i pulled into a parking lot after a light shower and kicked a shitty lost power steering. i knew right away i'd thrown the belt off got out threw it in the car and wrestled my steering wheel to the nearest socket wrench i put it back on in the rain. the socket wrench is now part of my glove box accessories. my 97z did the same thing when i cut donuts and this was the first one i've cut in this car when i bought the car i but a new gatorback belt on it. is there a solution to this problem?
Old 03-04-2008, 07:45 PM
jasonp31's Avatar
All stock pullies/accessories right? I'll have to look into that...never had the problem.
Old 03-04-2008, 08:20 PM
ROWDYZ28's Avatar
That makes 2^
Old 03-04-2008, 08:37 PM
96capricemgr's Avatar
Only time I ever had an LT1 throw a belt was when I put the wagon windows deep in a snowbank, that was a very differnt problem than this.
If you have had two different cars do it I think it is something YOU are causing,. If it was just one car I could attribute it too some mechanical defect.
Old 03-04-2008, 09:19 PM
MTBSully's Avatar
this just happened to me last week. My tensioner pulley was junk. Got a new one at Auto zone and have not had any problems since
Old 03-05-2008, 08:32 AM
RickyMartinZ28's Avatar
Strange problem... never happens to me...
It'll fly off and detroy everything in its path this afternoon...
-Rick
Old 03-05-2008, 08:35 AM
Bad93TA's Avatar
this happened to me also when i did a donut. lost the belt but it was fine, i was close to home and put it back on. its been fine...
Old 03-05-2008, 08:41 AM
Pro_built7's Avatar
new tensioner!!! if its stock, its time man
Old 03-05-2008, 04:24 PM
Powder96SS's Avatar
well if i'm gonna be pullin off a tensioner i might as well upgrade other pulleys as well any suggestions?
Old 03-05-2008, 04:59 PM
355z28's Avatar
my buddy has this problem on his formula and it only has like 27,000 on it...
Old 03-05-2008, 05:30 PM
Its like 2 bolts.
Might as well pull the engine while your at it.
-Rick
Old 03-05-2008, 05:31 PM
What do you think you are going to "upgrade" and what do you think this "upgrade" will get you??
Putting an underdrive on can be useful if sustained high rpm opperation poses a threat to power steering life or overheating, but that is about it.
Old 03-06-2008, 07:44 AM
Powder96SS's Avatar
[QUOTE=96capricemgr;8859305]What do you think you are going to "upgrade" and what do you think this "upgrade" will get you??
QUOTE]
thats why i ask for suggestions.
Old 03-06-2008, 05:39 PM
OK the suggestion is spend your money elsewhere.
Save it towards springs and rockers.
Old 03-07-2008, 09:33 AM
Powder96SS's Avatar
thanks. man throwing the belt off had a snowball effect. put the belt back on but while i was moving stuff around under the hood in the dark i got one of the heater hoses up against the alternator and it put a nice hole in it. car overheated antifreeze everywhere under the hood. replaced the hose. which wouldnt have cost that much but i ended up spending an additional $60 in advance auto parts while waiting around. armor all, tire shine, seafoam, wash n wax, spark plug gapper, magnet on a stick. they need to keep that stuff away from the register. anyway after i got to driving it for awhile i noticed under acc. it bogged down waited untill dark and looked under the hood now i have 3 bad spark plug wires i think it was because of all the antifreeze spraying everything. PITA.
Old 03-07-2008, 10:18 AM
djjab57's Avatar
Same here my bet is belt ten. pulley Its a ouick easy cheap fix. The only thing about buying one from auto parts is the wheel is plastic but a year and a 1/2 later no problems
Old 03-07-2008, 06:03 PM
Powder96SS's Avatar
in jegs and summit they have lt1 pulley sets but thats all it says lt1 polished aluminum pulley set it doesnt say what pulleys are included theyre only like $110 in summit but theres no picture either do the sets come with a tensioner?
