good stock cubes cam for cam only? w/4.11 and bolt-ons
i was wondering what is a good cam for a stock cubic inch ls1 for a cam and bolt-on only M6 car with 4.11 gears? i have read all the "LS1/LS6" books and a bunch of posts about cams but still dont know what i am looking for. i just need pointed in the right direction. i want an very aggressive idle. i plan on going to the track as much as possible and doing and some highway racing, but this is also my daily driver. i need some hp and tq i can use with 4.11 gears. if anyone has a cam in their car that they like, let me know. any input will help. thanks
I've thought about this as well, but I figure I'll blow any cam only car out of the water if I spring a little more for heads... but I would like to know the answer to this question as well...
You just have to dig into the posts, or else call comp cams and discuss with them your plans. I hope by cam only you are also talking about changing your valve springs (retainers too). Also expect to pay $400 to have the car tuned. Something like 224/224 .550/.550 115 or so is a reasonable daily driver.
Sounds like you want something bigger than the 224/224. The 4:10 gear will let you give up some low end torque. Look into something in the 230's, or do like I did and have Patrick spec you a custom grind and get everything from Thunder Racing.
i had been considering the ms4 because it has a good top end and i figured the 4.11's would help me with the loss of low end like you were saying. but im still not sure. i am only doing this once(because it's going to be a pain to install and cost a lot) so i want to make the right choice. thats why i am looking for as much input as possible.
WOW! agressive cam and a daily driver? you sound like me! I am using the 224/230 114lsa and want to go bigger. I also got 4.10's. this cam is alright but i also want bigger. I've been looking into the ms3 cam with a 112lsa and i am also getting info that the TREX cam is doable on a LS1, dont quote me on the TREX, its just what i've heard. But an M6 with 4.10's, i would say high 230's dur. and low .600lift. my $.02
check out flowtechinduction.com
or shoot ed curtis an email over there. he used to do custom grinds for me when i was buildin fords all the time.. excellent product the guy really knows his ****. he specs the cams out and gets comp to cut them to his specs. makes some of the most drivable hp/tq out there. anyhow, thats my .02. and when it comes time for me to cam up, i know where im goin.
My car is similar to yours, but I did do a cam. All the mods are in my sig. There's a dyno graph buried below in TA pics. It's not an aggressive idle at all, but it delivers good power with excellent DD manners.
