Sealing Washers
Sealing Washers
Does anyone know what the part number for the two sealing washers that helps seal the crossover tube to the back of the heads? Or where to pick them up? I haven't called GM and I figured that was something a local parts store would have. I may end up using the ones that fit on the ac compressor if I can't find anything. Thanks
Probably should change the bolts too PN#12552974. The early 93s had some odd sized heads, metric was too big and standard too small, and stripped easy, the replacements ( I think ) are 13mm.
I paid around $20 for 4 washers ( two each head ) and the bolts.
