Removing ABS and TCS
Okay guys quick question, I have found a link where it explains how to remove the ABS and TCS unit, which is cool but the Q I have is the guy who wrote the article when he did his ABS he used a Wilwood Brake Proportioning valve (I have that) but he only connected 1 line of his rear brakes don't both of them need to be connected and if that is the case wouldn't you need to have two valves? plan on doing this but want your guys advise. Just covering my bases.
The link is here: http://www.pharmacy.arizona.edu/staf...PropValve.html
Ponch
Ponch
FRONT - From master to Linelock and the l;inelock is design with 2 or 3 outs so I connected both my front lines to the linelock.
