Shim the oil pump relief spring or not?
Old 02-05-2003, 07:16 AM
BigD's Avatar
Default Shim the oil pump relief spring or not?
I am assembling an oil pump. I have searched high and low for this answer. Should I shim the relief spring for more oil pressure or not? I know some companies like ARE, MTI shim theirs, while Katech doesn't. One person posted he shimmed his .150", which to me seemed excessive. I would like to have "alittle" more oil pressure than stock. Has anyone here shimmed their spring? if so how much? and what was the end result for pressure? Does anyone have a pump from ARE or MTI and know what shim they use? Thanks, Darrin
Old 02-05-2003, 09:09 PM
BradWS6's Avatar
Default Re: Shim the oil pump relief spring or not?
TTT
Old 02-05-2003, 11:46 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I've used 3 small washers for a total of .110" sometimes they come out to .100" depending on the thickness of the washers. You can buy a bag of small washers at Radio Shack for $1.50 or so. Seems to add around 15-20psi, but those were on stroker engine packages which ran about 50-60psi warm at idle. Bearing oil clearance comes into play on any engine, if you have a "loose" engine you may not gain much pressure as a fresh engine.
Old 02-05-2003, 11:56 PM
xssive's Avatar
Can this be done with the pump still physically mounted on the motor? I am guessing it would be hard to deal with the spring....
Old 02-06-2003, 12:14 AM
-Joseph-'s Avatar
I think it would be a PITA with it mounted, it takes a little work to remove it if your that far though. You can wrench the pickup tube bolt loose for 20 minutes, or loosen the pan to get to it easier.
Old 02-06-2003, 12:16 AM
Nasty N8's Avatar
We shim oil pumps for the added pressure, and also debur and polish the vaines.
Nate
Old 02-06-2003, 07:59 AM
BigD's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nasty N8:
<strong> We shim oil pumps for the added pressure, and also debur and polish the vaines.
Nate </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What size shim do you use? Thanks!
Darrin
<small>[ February 06, 2003, 08:01 AM: Message edited by: BigD ]</small>
Old 02-06-2003, 01:22 PM
BigD's Avatar
<strong> We use right around .100
Nate </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thank you
Old 02-07-2003, 12:35 AM
Nasty N8's Avatar
Nate
Old 07-10-2009, 02:56 AM
Ford_Assassin's Avatar
Digging up an old thread, but where exactly is the spring located on the pump? Is it under the allen plug?
Thanks!!
Old 07-10-2009, 07:28 AM
LS1MCSS's Avatar
Yes it is.
Quick Reply: Shim the oil pump relief spring or not?
