how do i reach around 500rwhp
I have a 02 t/a ws6 with slp lid, k&n air filter, smooth bellow, polished throttle body and MAF housing descreened, ac delco iridium plugs and super conductor msd wires, and mac mid length headers, also loud mouth 1 exhaust system with a mac ory off road Y pipe. my cam is 224/231. i don't know much about ls1's yet, I haven't even had my car for a year. all this was done before i bought the car, I am trying to learn....i am wondering how to reach around 500rwhp or if it is possible. I don't want to put nos on the car if i don't have to but what should i do???? i talked to a guy here and he said the car should be putting around 400-410rwhp...??????? Anyone???????
Try a search and read stickies. https://ls1tech.com/forums/generation-iii-internal-engine/772576-got-cam-heads-rocker-machining-questions-about-ls1-ls2-ls6-read-me-first.html
That will get you started man.
500 rw takes a very healthy setup. something around 475 would be more realistic. a great set of heads like afr 205s or tfs 215s milled to give you 11:5 scr or so along with a full length header, cam like a 234/238 give or take should be good to go with a good tune.
as suggested the search will help you out quite a bit.
Nitrous is gonna be your most affordable way to get there. Especially with your current set-up.
You ain't putting down 400-410. With that cam i would imagine around 380 give or take. I would put a 125 shot on there. All other options will be very expensive. You've got a budget setup, my advice would be keep it that way and get some juice.
the recipe for 500rwhp N/A
wow, not obviously titled at all. you would never find it in the sticky.
one thing that is not mentioned in patrick g's recipe is research. saying you dont know much about ls1's yet and asking for 500rwhp is a sign that you may need some. good luck man
