May have bad ring
Old 03-06-2008, 06:27 AM
AFASTYZFR1's Avatar
Default May have bad ring
Car blew out dipstick last night and oil went everywhere. Will compression check it today. I pushed dipstick down and took a ride around the block and hit 3# and felt fine and dipstick did not come back out. I guess there is something wrong.......The motor still runs, idles, and drives fine...
I hope its ok.....any suggestions
Car only has 26500miles
Old 03-06-2008, 07:54 AM
cablebandit's Avatar
do you have the valve covers vented?
Old 03-06-2008, 07:19 PM
AFASTYZFR1's Avatar
no breather....plan on getting one if everything is ok
compression testing it in the morning
Old 03-06-2008, 08:10 PM
lmt0705's Avatar
sounds like you just boosted the crankcase, what are you doing for a pcv setup and breathers?
Old 03-06-2008, 11:19 PM
AFASTYZFR1's Avatar
stock pcv......except line that went to throttle body now goes down to ati inlet hat.....other than that, no breather or anything
Old 03-07-2008, 04:27 AM
EPP
EPP's Avatar
A broken ringland will normally be heard, although we've had them not make a sound at all. Compression test don't always show up a broken ringland either. The good news is that it really doesn't take much for the dipstick to pop up. Let me know what you find out, like I told you on the phone yesterday, I'll bet everything is okay. Bob
Quick Reply: May have bad ring
