Quick Question: Good installation kit for 3.73s
Old 03-06-2008, 10:05 AM
bowe1632's Avatar
Default Quick Question: Good installation kit for 3.73s
good install kit for 3.73s, what should it include and where can i get one...my search button did not work properly
Old 03-06-2008, 10:32 AM
connexion2005's Avatar
I would go with Motive's simply because IMO they work best with the GM carriers and housings. I've always heard that AAM is the maker of Motive Gears and that's actually what GM uses from the factory. In addition to the gear set if you want to do it right get a hold of a master install kit so you can replace your bearings, shims and bearing races. You will also need 2 quarts of gear oil as well as the limited slip additive if your using the Auburn Posi. Hope that helps ya!
Old 03-06-2008, 10:46 AM
camaroguy26's Avatar
yeah like connexion said a master install kit has all you need besides lube. most sponsors have them and it comes with bearings, shims, yoke nut, ring gear bolts, crush sleeve, loctite, and a brush with gear marking compound, oh and a new cover gasket and pinion seal.
Old 03-06-2008, 10:54 AM
bowe1632's Avatar
cool i will want a master install kit then, any sponser in particular
Old 03-06-2008, 11:32 AM
I'm sure they are all great but I absolutely love Ws6store.com. There shipping is always very fast and I have gotten great customer support on the phone with them also.
Old 03-06-2008, 11:36 AM
ping2day's Avatar
I used the Motive gears and master install kit for mine.
Old 03-06-2008, 12:41 PM
omcar's Avatar
Make certain you get Timken bearings.
Old 03-06-2008, 03:03 PM
Viper's Avatar
Thunder Racings master kit is what I used back in 2002. I also did the solid pinion racer and TA cover.
Old 03-06-2008, 03:36 PM
FiredUpZ28's Avatar
Very true. They have been great for me as well.
Old 03-06-2008, 04:39 PM
02T/A-WS6's Avatar
i got my gears and install kit from neweraperformanceparts.com
They are a sponsor on here and have awesome prices...definitely have to check them out.
