Lifter preload question
Old 03-06-2008, 02:54 PM
xBROKEx's Avatar
Default Lifter preload question
im using LS7 lifters with stock RR's, prc 2.5 5.3L heads, TV3 cam. Do i need to mess with measuring lifter preload or should i be fine.
Old 03-06-2008, 03:10 PM
Sigforty's Avatar
You never mentioned anything about the pushrod size you are using. I would suggest you always check the preload when you make any changes to pushrod length, cam base circle, or cylinder heads.
Old 03-06-2008, 03:12 PM
xBROKEx's Avatar
sorry, 7.4 pushrods
Old 03-06-2008, 04:16 PM
JPH
JPH's Avatar
I would check, to see where you at atleast.
