Taylor Wires for LT1 any good?
Old 03-06-2008, 04:21 PM
Masochist's Avatar
Default Taylor Wires for LT1 any good?
Anyone w/ experience with these wires(gunna be bought from Summit) can say they are a quality piece? I'm trying to save some money from the MSD 8.5.
My current wires were routed incorrectly around my LTs, they are starting to fray and the car is beginning to misfire a little under load. Does anyone know what I'm going to need to route these bad boys correctly?
Thanks for any opinions.
Old 03-06-2008, 04:31 PM
axeman's Avatar
I got em they are fine so far. They've been on since August.
Old 03-06-2008, 04:35 PM
Schweet97Z's Avatar
http://thunderracing.com/catalog/?ac...vid=4&pcid=104
very bottom of the page.
Old 03-06-2008, 04:45 PM
RickyMartinZ28's Avatar
Had my taylors for 5 years and 90k miles. Still look new and work awesome.
-Rick
Old 03-06-2008, 05:33 PM
Masochist's Avatar
Originally Posted by Schweet97Z
That is exactly what I wanted. However, will they work the same with Canton valve covers?
Thank you all for your opinions
Old 03-06-2008, 05:54 PM
socal's Avatar
i had a set and they kept falling off the plug, i wont buy another set again
Old 03-06-2008, 06:21 PM
Schweet97Z's Avatar
I cant answer that. Call Thunder and ask them. Im sure they can be made to work
Old 03-06-2008, 06:36 PM
JoeliusZ28's Avatar
I like the kit, NOT impressed with the wires. They arced a lot at first, and they still arc a little bit on me when i gun the throttle hard at a low RPM. Someday im going to switch to different wires, but i dont feel like dealing with that nightmare yet. Theyre OK wires.
Old 03-06-2008, 06:52 PM
hashtagBMW
Speed Density's Avatar
Ive had a few sets, they are OK.
I wouldnt buy Taylors again though.
Old 03-06-2008, 07:04 PM
Jditlfm's Avatar
I like mine you can get the side mounted ones for the canton valve covers like i got. They actually bolt to the heads and not the valve covers.
Old 03-06-2008, 07:22 PM
ROWDYZ28's Avatar
Oh ya they are good. I went with a nice MSD set and love them.
Old 03-06-2008, 07:32 PM
M6 Swap's Avatar
mine fit but not to good. wouldnt buy another set. i want to go back to factory delcos personally
Old 03-06-2008, 08:01 PM
porksoda's Avatar
I haven't had a single problem with mine since I put them on! They have been on my car since August of 2007 and I daily drive my car without a hiccup. I can look at them at night and they don't arc one bit. These are the OTVC set from Thunder Racing by the way.
Old 03-06-2008, 08:03 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I had them on my 350 Chevy Silverado for 3 months......arcing, falling off plugs, just terrible....MSD ALL THE WAY.
Old 03-06-2008, 09:09 PM
Fastbird93's Avatar
They're all I've run for years now. No problems noted.
Old 03-06-2008, 09:16 PM
strkt_&_blwn's Avatar
I've had the same problem with my MSD's
I'm switching to the OTVC kit hopeing to take care of it.
Old 03-06-2008, 09:48 PM
fergymoto's Avatar
I used to run them till my coil wire out of nowhere started arcing so bad my car wouldn't even start. I have run several sets of MSD wires too and could see spark leaking out around the boot. Now I run the Moroso wires and I like them a lot. I actually have them mounted in the factory wire holders with my Pacesetter LTs and the setup is great with plently of room.
Old 03-06-2008, 09:56 PM
9sec93's Avatar
i prefer the taylor wires over the msd any day. every set of msd wires i put on an LT1 have had problems with them cracking and arcing pretty bad.
Old 03-06-2008, 10:00 PM
JoeliusZ28's Avatar
my personal opinion is that niether MSD nor taylor are any good. Ive had the best luck with factory delcos, problem is they arent the right length for OTVC!
Old 03-06-2008, 10:06 PM
hyperzone's Avatar
I've had my taylor wires on there for like a year or two. No problems I know of. Using a delteq unit and I also have these braided fiberglass boots/sleeves where the wires are near the headers.
Quick Reply: Taylor Wires for LT1 any good?
