ls2 in notchback help
i have a 87 notchback which i got a ls2 motor for it, should i use the stock kmember? what headers are out there to work with this swap??
here is what it looks like i live in michigan an help would be awsome thanks
If you want a kit that bolts in setup for drag racing AJE and Kooks make the k-member/headers. Also try the search function. This is like the most played out question asked in the forum....
Yeah nobody has done this conversion before
On the 58x issue -- search is DEFINITELY your friend. You didn't provide enough information to answer you question either. The 58x works just as well as a 24x wheel, provided you get the PCM that matches
