5.3 Heads or tune
5.3 Heads or tune
Ok so Im in a delima of what should I do I have a car that should be tuned but any way here are the mods
Tsp T2 cam 232 234
241 stock heads
Dual timing chain
Lingfelter (cantspell) oil pump
SVO 30lbs injectors
BBK SSI intake with 80mm TB
Long Tube 1 3/4
2 1/2 xpipe through exhaust
not installed
Patriot Springs Kit good for .650 lift
Patriot Shaft mounted roller rockers 1.7
So here is my Q
I have $2000 to splerge on mods should I
1 Get TSP 5.3 stage 2.5 Heads and bump compression to11.1 and have a few bucks left over for what ever?
2 Get HP tuners, wideband, and get what I have so far and good tune?
3 Car is good enough and save up for...(insert something)
Please give me any suggestions you feel neccessary This will probably be my daily car but at the same time track *****
I have searched and found nothing in regards to this but I posted my recient dyno an it has aft readings check out my other post
Thanks
Tony
Tsp T2 cam 232 234
241 stock heads
Dual timing chain
SVO 30lbs injectors
Long Tube 1 3/4
not installed
So here is my Q
Thanks
Tony
