King Bearings?
Old 03-06-2008, 07:52 PM
WhiteStripes's Avatar
Default King Bearings?
So after doing a search on this company, I've found that they are preferred by Lunati, so that should say that they are good, and also I believe TR uses them, but I've never heard of them. I've only heard of Clevite, and Federal Mogul. A stroker kit I was looking at uses the King Areculars and was wondering if they have a good reputation?
Old 03-06-2008, 07:56 PM
fossil's Avatar
so far so good for King bearings....
Old 03-06-2008, 08:31 PM
RedLT4Mike's Avatar
Mine are running fine
Old 03-07-2008, 12:57 AM
1997bird's Avatar
I know of a 1500+ HP drag car running them with zero problems. I've used them several times without bearing wear after 52 races on a circle track application. I wouldn't have any problem useing them on a engine build.
Old 03-07-2008, 01:17 AM
nvmy2000ss's Avatar
well knowen in circle track.
Old 03-07-2008, 10:13 PM
busta9876's Avatar
I used a set of 360 degree oil groove mains in a 383 LT1 I built, no problems. I have heard they are softer then clevite or FM. Higher embedability.
I work for Jasper Engines & Transmissions, we install King bearings in certain oversizes on Chevy 305s, & 350s. Building 70 engines a day.
Old 03-08-2008, 12:12 AM
16floz470ml's Avatar
I got the Lunati stroker kit and it came with King rod bearings. The bearings are made in Israel. Five of them had raised bumps on them so I threw them away and got some Clevites.
Old 03-09-2008, 08:08 PM
CalSpeedPerformance's Avatar
weve used them in alot of builds...high quality
Old 03-10-2008, 12:50 AM
ThunderStruk's Avatar
We use King bearings in a lot of our motors. King makes a real nice bearing.
Old 03-10-2008, 05:16 AM
pwtr02ss's Avatar
I just took a blown injected BBC apart over the weekend. Had 20 runs on low boost. All the rod bearings were peeling apart. I prefer the ACL's.
Quick Reply: King Bearings?
