Does stock 6.0L block and stroker crank = 396
Old 07-20-2003, 01:44 PM
Billiumss's Avatar
Default Does stock 6.0L block and stroker crank = 396
If a stroker crank gives you a 383 in a stock LS1 block and if you use that crank in a bored .030 over 6 liter block which give you around 406 cubes, if you didn't bore the 6.0l block, would it be a 396?
Old 07-20-2003, 02:03 PM
fast2001's Avatar
Default Re: Does stock 6.0L block and stroker crank = 396
This website will answer your question
http://www.aera.org/tech/cube_calc.html
Old 07-20-2003, 02:08 PM
Crazyquik's Avatar
A stock bore 6.0 is 4.001"
The crank you're talking about is a 4.00" stroke crank.
This combination would give you a 402. Weren't most of the later cars that were badged "396", actually 402s?
If you're really hung up on getting a 396, you could take a stock 346 and bore it .010 (maybe) and use the big Lunati 4.125" crank for 396. Or a 4.125" resleeve with a stock crank offset ground will yeild 396. Or a 6.0 liter bored .060 (you'll need to sonic test for core shift first) and use the Scat 3.8" stroke crank, which gives 393.
J.
Old 07-20-2003, 02:13 PM
Billiumss's Avatar
How much does a honing take out on a stock un-touched block?
Old 07-23-2003, 12:06 AM
bigeller's Avatar
My 6.0 was honed .001"
Old 07-23-2003, 12:26 AM
LS1Tech Co-Founder
Nine Ball's Avatar
You can safely bore out to 4.030, and push the limit with 4.060 on an iron block. Honing does very little to a bore size.
Tony
Old 07-23-2003, 04:34 AM
Nickn20's Avatar
just do the 402 and call it a 396 lol
Old 07-25-2003, 05:06 PM
gillbot's Avatar
