quick question
Old 03-06-2008, 09:58 PM
fuseone's Avatar
Default quick question
how do you get the plastic peice off on the inside of the door thats near handle because i gotta change that little red light thats in there, and dont know how to get the plastic peice off?
Old 03-06-2008, 10:08 PM
1FST-Z's Avatar
There's a little red light in your door!? BEWARE: that's the glowing red eyes of the gremlins!!!
Old 03-06-2008, 10:14 PM
fuseone's Avatar
yea man i just noticed because i seen one on the passanger door and then see the driver door had one but didnt go on i was amazed that i never took notice lol
Old 03-07-2008, 11:31 PM
1FST-Z's Avatar
Are talking about the lights that light up the power window and lock switches?
Old 03-08-2008, 01:20 PM
fuseone's Avatar
thats the one
Old 03-08-2008, 01:35 PM
1FST-Z's Avatar
oh, well I guess that makes sense if you're driving a TA, cuz Pontiac probably matched the light with the rest of the interior lighting (red). If you drive a Camaro, the previous owner apparently installed aftermarket LEDs or something in there. Anyways to answer your question, I'm not entirely sure, hehehehe. I know you can "wiggle" that plate around...so I think maybe you can sorta pry the switch plate up to where it pops off and then maybe get to the light that way. Try it!
Old 03-08-2008, 01:40 PM
zdc590's Avatar
You can pop the whole assembly off....really easily.....too easy actually. Gm quality right there
Old 03-08-2008, 02:33 PM
Save the manuals!
wssix99's Avatar
First use a screwdriver or prybar to pop off the plastic lock slider. (The one with the red sticker on it that shows when the door is unlocked.) It will take a little bit of force - be careful not to scratch the plastic under the slider.
Then remove the trim screw in the well behind the pull handle. You can then wiggle the plate off. The bulb is in a socket that twist-locks in to the plate.
