when to stop using hpp3?
Pathological Modifier
Re: when to stop using hpp3?
I am going to have to agree with Cal on this one. I would not run those two together. The real uses are on lightly modded cars for adusting the Fans and the gear ratio changes.
Love to see the 3 foot true duals with side exits! Got a Pic?
Ryan K.
Ryan K.
its supposed to be 3 inch...its a typo..but I think I have a pic of my setup on this computer somewhere, ill let u guys know
The problem with the HPP3 is you have only two choices: 1) use HPP3 tuning 2) don't use HPP3 tuning. You can't custom tailor it to the particular set of mods that you are running, so it's just a shot in the dark as to whether you will be running the correct AFR or something worse than you have now. You need to be able to make fine adjustments on a number of parameters to come up with a good tune.
