s10 power steering AN adapter
Old 03-07-2008, 02:25 PM
SUPERWAKE502's Avatar
Default s10 power steering AN adapter
6.0L goin in a 94 S10. Theres is a AN adapter from russell but I'm not sure of the size to get. I think there is two. I have the truck accessories on it if that helps any. I want to convert to an AN line from the pump to the steering box. Also the return line is just a rubber line that slips over that fitting in the box. I also need to know that size so I can get one.
I've been searching but havn't found the exact info that I need to do this.
HELP!!!!!!!!!
Lee
Old 03-15-2008, 08:54 AM
ponti-yak's Avatar
I am working on the same adaptation, but I don't have a Russell catalog. The box fitting for the HP hose is 18x1.5mm and the pump end is 16x1.5mm.
Please post the part numbers you come up with.
Bill.
Old 03-15-2008, 10:53 AM
pcmcobra's Avatar
http://store.summitracing.com/partde...0&autoview=sku
I got this part number from a guy who did a 5.3 swap on his 78 C10.
Not sure if it's what you are looking for, but maybe headed in the right direction?
Quick Reply: s10 power steering AN adapter
