General Maintenance & Repairs - Modded DRLS
Joshiedoom
03-07-2008, 09:23 PM
So it has come to my attention that if you DD your bird that your DRL sockets will get ruined.. often.. especially during winter.. Ive replaced mine all too much and today I noticed that the socket is almost directly exposed to the lower bumper opening.. WTF... what a poor design.. SOOO
Im thinking new housings.. and getting two new sockets and putting them on top of the housing.. then expoxying a plastic template on the bottom to seal it up.. when the socket is on the bottom water can pool up(due to gravity) in the connectors.. seems like if it relocated on top that it would help with this...
FEEDBACK REQUESTED
1FST-Z
03-07-2008, 11:22 PM
Patent it, and fuckin' SELL IT. Fuh real. And do it for the Camaro as well, goddamn bulbs.
Joshiedoom
03-07-2008, 11:41 PM
Ive replaced about 20 bulbs since october...
wssix99
03-08-2008, 10:23 AM
Are your lenses good? Sounds like the bulbs are getting wet.
Being in the bumper, they tend to get hairline cracks in them which lets in water - which causes things to go bad. If any of your 20 bulbs have exploded, its definitely a water issue.
Joshiedoom
03-08-2008, 05:23 PM
Lenses are good. My car is a DD btw.
NateLS1
03-08-2008, 06:00 PM
I just got new lenses/housings, new sockets, and new bulbs. I also put on custom cut clear bra to cover the lenses so rocks and crap dont crack them allowing water in. Done
xterminator
03-09-2008, 10:06 AM
natels1 how much did all that cost you?
99monguse
03-11-2008, 01:35 PM
Problem is that the sockets get wasted here are the part numbers for new sockets. The sockets have leads on them too.The bulb socket part number is 88986416 list $39.76 each(CAMARO)and part #12159662 list $64.65 each(TRANS AM) The Trans Am unit is a 3 way female with leads. This socket has the leads on it too. The price has gone up a bit since I did mine. The part number 12159662 will also work with standard Pontiac Firebird and FORMULA models. The Trans Am lamps are different(daytime lamps).
Joshiedoom
03-11-2008, 02:08 PM
Autozone...10 bucks
crazymofo1986
03-11-2008, 05:21 PM
whats the part number at autozone everyehere tells me its a dealership socket
ae13291
03-11-2008, 06:51 PM
i never heard of this before! mine are good i even changed the bulbs and put brighter ones! and mine is a DD
phoenixv8
03-11-2008, 06:55 PM
yeah, sounds like your getting water in there. You might want to take the housing out to see where its coming in from. You can get them cheap on stealbay for about 25 or something.
Joshiedoom
03-11-2008, 08:25 PM
Any gm tailight turn signal socket..blade style type.. they have it in the electronics/fuses/bulbs/wire/toggle switch section
Joshiedoom
03-12-2008, 12:32 AM
Poor Design is where the water is comming from :)
LastHawk
03-14-2008, 02:18 PM
I just got my lamps and connectors in the mail today. I will definetly come up with something to keep the water out of there. You guys think its water getting into the housing AND/OR condensation collecting? It looks like around the base of the socket connection that there is a foam ring. sure it "may" keep "some" water out and also allow the water to collect and dry there... I dont know...
I'm just frinkin sick of changing bulbs every 2 months on a +30K car...
Joshiedoom
03-14-2008, 02:24 PM
Try moving it to the top. and sealing up the bottom'
LastHawk
03-14-2008, 02:27 PM
I saw your other posts Joshie and will definetly think about it. I don't have a bunch of supplies or tools to work with but I may give it a shot withthe best of what I got. Very good idea...and Id be psyched to see how well it works.
Joshiedoom
03-14-2008, 07:38 PM
A dremil and a file and a couple of hours should do it..
