HELP!!! How do you remove the....
Old 03-08-2008, 03:36 PM
Red_Z-29's Avatar
Default HELP!!! How do you remove the....
How do you remove the rear offset shift lever roll pin and the rear offset lever and isolator cup. I pulled the t-56 out of my 02 ss and removed the shifter bolts and the shifter. The directions i got off of all-data say #8. Remove rear offset shift lever roll pin. #9 Remove rear offset shift lever and isolater cup. But i have no idea how to get it off!!! Any Ideas!!!
Old 03-08-2008, 04:28 PM
97BlackLT1TA's Avatar
it might be a little stuck, give it a little tap towards the end of the shaft with a brass drift.
Old 03-08-2008, 05:27 PM
Red_Z-29's Avatar
I have tried tapping it, i just tried again, and nothing, it is on there pretty good, it doesent even wiggle at all. i am sitting here just looking at the thing puzzled. when they say remove the rear offset shift lever roll pin, is there actually a pin? there is something there that looks like a pin, but how do you get that out?
Old 03-08-2008, 06:09 PM
Oh you dont have the roll pin out?
In that case you need to use a roll pin punch and a hammer and punch it through.
Old 06-13-2009, 08:18 PM
AChotrod's Avatar
perfect!
Quick Reply: HELP!!! How do you remove the....
