Are there any torque specs for head bolts that aren't tty?
yeah, there is a procedure and a specific torque sequence for ARP bolts. I'm sure you can find it if you search. Also, the bolts should come w/ instructions.
https://ls1tech.com/forums/showthrea...rp+torque+head
Another post about the same problem, with an answer.
https://ls1tech.com/forums/generation-iii-internal-engine/878572-does-any-one-have-torque-specs-arp-234-6301-rod-bolts.html
