what can i do to AFR 205
Old 03-08-2008, 05:57 PM
'02SOMz28's Avatar
Default what can i do to AFR 205
Buying some Afr 205cc to go along with my 231/237 112+2 comp cam and a fast 90 that will be ported for the heads... What can i do to these heads to make them better and still run 11-1 compression
Old 03-08-2008, 06:55 PM
vettenuts's Avatar
Contact Tony Mamo.
Old 03-08-2008, 08:43 PM
joker machine's Avatar
port and polish maybe different valves
Old 03-09-2008, 12:09 AM
discostu's Avatar
check out patrick g thread recipe to 500 rwhp i think he used afr 205s
Old 03-09-2008, 12:55 AM
chvycmaroz28's Avatar
do u have a link to that recipe? haha
Old 03-09-2008, 01:28 AM
landonew's Avatar
Its in the sticky. Mamo suggested doesn't suggest that you do much accept upgrade to their valve springs, use 62cc combustion chamber (raise compression), and have him port your IM. Pretty solid combo if you ask me. My car dynoed 436 before the tune... Of course then it spun a bearing, but that ain't the heads fault. With that cam, you should be well into the 460s I would think, but then again these cars respond differently so who knows.
Old 03-09-2008, 04:10 AM
PREDATOR-Z's Avatar
Nothing, that is the best thing to do. Just run the right springs and mill the right amount with comfy PTV.
The best you can do to this combo is degree the cam, run thinner gasket for better quench (do that before mill so you don't mill too much) and spend a good amount of time tuning.
Old 03-09-2008, 04:30 AM
miami993c297's Avatar
Best advice for those AFR heads, perfect out of the box...
Christian
Old 03-09-2008, 11:31 AM
Ryan02SS's Avatar
I agree. AFR spent lotsa R@D $$ to make these perfect out of the box. Messing with them will only hurt.
