cooling line on back of heads
There is a coolant line on the back of the heads and when i took off my intake manifold to pull the heads to send them to lloyd elliot i noticed that the two washers (not sure if thats what there actually called) that seal between the head and bolt are in pretty bad shape. Where the heck do i buy these things! Its like a washer that has a silicone middle to not let coolant get by, help me find these please
I just did some head work, and had them replaced with oil drain gaskets Dorman part # 65269 they are metal around the ring and rubber in the center, youll need four of them and they're only about three dollars each, you can find them at your local parts store I got them at advance cause I work there
