wheel hope and lowering question
Old 03-09-2008, 11:25 PM
tage9239's Avatar
Default wheel hope and lowering question
so my car used to just spin tires when i hammered on it, now with a bigger motor and mods it wheel hopes so bad that i am afraid that i will tare the rear end out, so what would be the first thing i need to do to make the rear end stick, panhard bar, sub frame conn. tourque arms?????????????????????????????? also i have pace setter lt headers and was wanting to know if i can lower my car with out rubbing the road, i run 275/35/18 tires. thanks 2001 ta 6speed........
Old 03-09-2008, 11:27 PM
CranMaro99's Avatar
Maybe you'll rub? lol
Old 03-10-2008, 02:11 AM
waldershrek's Avatar
LCA's and brackets will cure that wheel hop
Old 03-10-2008, 09:00 AM
Black02SLPSS's Avatar
Torque arm, lca's and the relocation brackets will all help with the wheel hop
Old 03-10-2008, 09:11 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Lca's first, then if the wheel hop is still present I would use the relocation brackets.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 03-10-2008, 02:51 PM
SOMbitch's Avatar
Yes you can lower without rubbing.
Old 03-11-2008, 12:13 AM
CW00BlackTA's Avatar
If you lower, you'll want relocation brackets and an adjustable panhard rod to correct the geometry issues. I'd go with upgraded LCA's at the same time. If that doesn't work (it didn't on mine), go for a torque arm. The Pacesetters sit up nicely and won't rub on a lowered car--but you have to tuck the y-pipe well.
Old 03-11-2008, 08:53 AM
z28bryan's Avatar
The lower down your lower control arm mounting point on your axle is compared to the lca mounting point on the chassis, the better off you are at curing the wheelhop and putting down better overall traction.
One guy in a local message board was doing 2.5 60 foot times until he put on lca relocation brackets. Now he's doing 1.7 60 foot times. There's probably some "learning how to launch" factor in there as well, but that's almost a whole second better.
Old 03-11-2008, 08:58 AM
Kleeborp the Moderator™
MeentSS02's Avatar
So he cut a full 0.8 seconds off of his 60' times with only that one mod...right. I can assure you, they don't work that well, and that isn't the whole story.
Old 03-11-2008, 12:02 PM
z28bryan's Avatar
hence why I said theres some learning how to launch factor possibly in there too. obviously not many can launch the same every time, and the more you do it you probably lower the time. Either way, that's a good improvement and sufficient enough for me to personally believe that the lca relo brackets helped improve his 60 times
Old 03-11-2008, 12:53 PM
ZMONSTER!'s Avatar
Wheres Mr. Strano to give us the difinitive answer?
Old 03-11-2008, 01:21 PM
z28bryan's Avatar
You're better off asking people who've tested the before and after effects of the relo brackets on the strip. Not sure if Sam has done that or not.
Old 03-11-2008, 04:03 PM
MeentSS02's Avatar
There is POSSIBLY a learning curve involved?
Old 03-11-2008, 04:23 PM
z28bryan's Avatar
I'm lost. I can't tell if you are laughing at the fact that I suggested there's a learning period in getting your max 60 times down, or if you are laughing because there obviously is one in sarcasm.
I've never been to the drag strip before, just the local spectator drags that I participate in, so I can't really tell what type of 60's I'd pull my first time. But I'd imagine my first one won't be that great.
If it's anything like the local event I do, there's a learning curve there. It has taken me a few years to nail it down too, out of 4 events a year.
